TwinTurbo.NET: Nissan 300ZX forum - engine temp sensor is the coolant temp sensor..
Subject engine temp sensor is the coolant temp sensor..
Posted by Drk93TT on September 15, 2008 at 10:34 PM
  This message has been viewed 176 times.
In Reply To Weird Erratic Idle posted by elcid on September 15, 2008 at 09:57 PM
Message the coolant is what makes the engine temp what it is.
The yellow connector on the coolant pipe above the W.P. is the ECU sensor,
the black one is for the actual gauge in the cluster.
As far as the idle goes, sounds normal to compensate for more engine load
with the fan on, then stabilizing.
